Anyone here use the Phaeton two piece rotors?
I have been researching this on rs6.com and on here, found part numbers, but no luck locating them...
Anyone have a source for these? Part number is 3D0 615 301 N.
***(after doing some calling oempl.us has them for $400.00 each)**
Looks very promising, as they should reduce the unprung weight by ~5lbs a corner.
Thoughts on this setup?
Part is shown halfway down page.<ul><li><a href="http://www.rs6.com/forum/showthread.php?t=16747&highlight=phaeton">http ://www.rs6.com/forum/showthread.php?t=16747&highlight=phaeton</a</li></ul>
This is the same design BMW uses for its factory floating rotors (radial pins). The only shortcoming is the pin type of floating disk causes an obstruction of cooling flow to disk vanes.
To this day, however, I cannot get over how much those things weigh! BTW, 5 lbs is very significant.
thread a while back about the Phaeton rotors, they were a little heavier but quite a bit cheaper.
