DRC & extended warrantly options
Hello All,
For those of you who have one or have done the research - Does anyone know if there is an extended warrantly that will cover the DRC system?
I've already discussed this somewhat with the FL administrator of Audi's extended warranty program. Guy said if DRC part of the shock, it's not covered; if not, there should be coverage. He had no definitive answer, tho, because there had been no DRC repairs under the extended warranty at the time I talked to him (maybe 9-12 months ago).
The Audi extended warranty provider (in my case Fidelity) actually provides a service contract. My advice - call them and ask.
When I called them three times over a two week period, I was told each time that since the spring is mounted on the damper, they consider it a strut, which would be covered. One of them went so far as to 'look it up', and he said it was a strut in their replacement part catalog. However, the English translation of the German part name (translated from Japanese) shows up as 'shock' on one of the dealer computers, while the rubber mount is listed as a strut mount. Audi's own literature (technical specifications) lists the car as equipped with 'shock absorber struts'. Aftermarket parts catalogs list them as struts more often than not.
I had my dealer call the warranty provider to determine what would be what, as I didn't want to spend big $ on a contract that wouldn't cover DRC. After calling, he confirmed that DRC components, inc. the dampers, would be covered. So I bought it. When push comes to shove, however, we will know the real answer. I think the key is to make sure the repair bill does not say shock, and to remind the warranty claim agent that your car's strut has the spring mounted on it.
PS - there are several definitions of 'strut' and 'shock' around. A few identify a damper that does nothing but dampen, is a shock - if it does anthing else, like suspend a spring, locate or position the hub, etc, it is a strut. Others say that any damper that does not 'locate and define the movement of the suspension' is a shock. So a damper that acts in place of an upper control arm would be a strut. These definitions conflict, and hence the ambiguity - we all must be gluton's for ambiquity, as that's what Audi is best at...
sud1986
A4 allroad (B8 Platform) Discussion
10
01-21-2015 10:25 AM
heymoe
12-22-2005 09:37 AM
