Low boost on a O.CT chipped RS6
Everyone,
I have an 03' RS6 with the O.CT engine and transmission chip, K&N, Milltek downpipes, cats, and exhuast, and hyperboost DVs on a car with 31,000 miles.
I just installed a VDO boost gauge today and it looks great, but it is reading 12psi MAX and bleeds off to around 10psi at redline. I thought maybe I have a hole or leak in the gauge line so I ran a new one outside of the car, through the window, and into the gauge as a test. I had the exact same readings of 10-12psi. During idle it is reading 20 Hg of vacuum.
I read the O.CT chip should be running 16psi and I'm seeing 4psi less than that. Today is in the 30s F here in Pennsylvania.
The car has 93 octane in it or at least that is what the pump said. I also replaced the rubber hoses going to the DVs in case one of them had a leak, but no difference.
I do have a VAGCOM, but I can't record block 115 because the battery is dead in my laptop and won't run without being plugged in. While I'm sourcing a new battery do you guys have any idea?
Before putting in the gauge I've noticed the car doesn't seem to have as much power as normal and then later it is fine. I'm almost leaning toward replacing the N75.
Any other ideas? I assume most will want to see a log of block 115.
Thanks,
Chris
Thanks,
Chris
interesting... I always would have thought that turbos are more efficient in the winter, because the intercooler doesn't have to work as hard. I've talked to others with the O.CT chip and they are running about 15.4psi MAX and I'm running 11psi.
Though I first need to log block 115 and go from there. Just trying to think of alternative solutions until I get the vagcom hooked up.
Thanks,
Chris
Thanks,
Chris
ECS Tuning-Audi
A4 (B8 Platform) Discussion
11-30-2016 06:09 AM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-09-2015 12:00 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-09-2015 11:51 AM
ECS Tuning-Audi
09-08-2015 01:08 PM
