Need a little help gang. has anyone here suffered ANY reduction in boost due to hi temps or other?
As we continue to try and diagnose what the hell is affecting my motor, my SM asked me if anyone else was reporting these symptoms..
So, have any of you noticed an unexpected reduction in boost while driving your beasts? If so, please explain..
Thanks!
Thanks!
The turbo can still make excessive boost in high temperature situations, but due to the higher ambient temperatures, the engine is much closer to detonation at a given boost level as compared to a lower ambient temperature.
Detonation occurs somewhere around 1075 degrees absolute, which is a a combination of ambient temp, heat created due to compression in the cylinder and heat created from compressing the air by the turbos. That's why a more efficient intercooler is preferred, it keeps your charge air cooler.
Therefore, the ECU see detonation earlier in higher ambient temps, so it backs off boost or retards timing.
EndlessCorners
Audi Original "S" Cars
06-01-2008 09:15 AM
biturbopassat
01-07-2008 12:36 AM
LuvnhatemyA6
12-03-2006 01:19 PM
Avantgarde
05-07-2005 03:25 PM
