RS6 brake system
RS6 brake system
Hello all,
I have AUDI S6 PLUS, 1997 year. The original brake system is, front - 323 mm and rear - 269 mm.
I want install for my car brake system from AUDI RS6, front 365 mm and rear 335 mm.
Maybe some AUDI man can help me?
I hope for you understanding
AudiWorld Expert
Yes, you can install those on your S6+, but you will need 18" wheels...
...to clear the calipers. I had considered a set of those from a local RS6 owner when he upgraded his brakes, but decided that if I were to spend any $$ on brakes, I'd go with the Porsche kits from ECStuning.com. Much more choice for pads, easy (and not as expensive) to replace rotors down the road, etc. etc. etc.
adapter required?
don't the s6+ brakes mount on the front of the strut?
the brembo's will require an adapter to provide the lateral fixing points...
see link<ul><li><a href="http://pictureposter.audiworld.com/53706/1.jpg">rhs rs6 brake</a></li></ul>
