RS6 vs E55...discuss...
#62
Interior width is actually the same as a B5 S4
I know this to be the case because I owned both for a while and measured myself. When I asked about it, the response was that I shouldn't be surprised because the B5 A4 or S4, the current A6 (basis for the RS6) and even the Passat come from the same platform. So, all would have the same interior width.
#64
AudiWorld Expert
Didn't work for me :-(
170hp 1.8T in the fall of 2000 was good power at a reasonable price...by 2002 it was a slow POS that had far too many electrical problems and turbo lag got annoying...
#69
I don't know; I only measured cabin width
I took a tape measure and stretched it from one rear door opening to the other, in each car. Inches were identical. I was blown away but couldn't deny what I saw. My RS6 interior does seem larger, but it must be due to the increased length and the lighter colors (silver in the RS6, black leather in the S4).
If you really want the other specs, they might be available in some car mag articles or maybe product literature from Audi.
#70
I checked the specs. Quite a huge difference between the two.
The first is the A6 and the second the A4. The A4 weighs more? Go figure.
Exterior
Length: 192 in.
Width: 76.1 in.
Height: 56.4 in.
Wheel Base: 108.7 in.
Ground Clearance: 3.4 in.
Curb Weight: 3958 lbs.
Interior Front Head Room: 37.5 in.
Front Shoulder Room: 56.2 in.
Rear Head Room: 37.8 in.
Rear Shoulder Room: 55.7 in.
Front Leg Room: 41.3 in.
Rear Leg Room: 37.3 in.
Luggage Capacity: 15.4 cu. ft.
Maximum Seating: 5
Exterior
Length: 180 in.
Width: 70 in.
Height: 54.8 in.
Wheel Base: 104.5 in.
Ground Clearance: 5 in.
Curb Weight: 4013 lbs.
Interior Front Head Room: 38 in.
Front Shoulder Room: 53 in.
Rear Head Room: 36.3 in.
Rear Shoulder Room: 45.1 in.
Rear Leg Room: 32.4 in.
Luggage Capacity: 10.2 cu. ft.
Maximum Cargo Capacity: 10 cu. ft.
Maximum Seating: 4
Exterior
Length: 192 in.
Width: 76.1 in.
Height: 56.4 in.
Maximum Seating: 5
Exterior
Length: 180 in.
Width: 70 in.
Height: 54.8 in.
Maximum Seating: 4
