Am I correct that we can still get a XM module for the 2008 RS4?
in the future.
If the merger goes through it won't really matter which one you have though.
The fine print says you will be able to access SOME of XM's programming on Sirius and SOME of Sirius' programming on XM. They both are ridiculously tight on bandwidth at the moment so there is no way either can take on the other's full lineup.
To do the new ala carte picking of channels or have access to every channel, you will need a new radio.
View the table at the bottom of this link to understand what packages will require a new radio (marked with *). You'll notice as an example XM Everything has 170 channels...XM Everything + Select Sirius has 180 channels. What those 10 channels will be is going to be interesting.<ul><li><a href="http://www.siriusmerger.com/uploads/FINAL_New_Package_Release_7-23-07.pdf">http://www.siriusmerger.com/uploads/FINAL_New_Package_Release_7-23-07.pdf</a</li></ul>
dad2rem
RS4 (B7 Platform) Discussion
06-13-2008 07:41 PM
pmoneyt
12-09-2001 10:52 AM
pmoneyt
12-09-2001 08:07 AM
