Audi B7 RS4 Supercharger
#11
Otherwise, other than dropping a v10 or changing body panels to CF pieces, there's Nothing I can think of.
#12
why not call JHM and get on the list for their kit? It'll be well under the price of the 'other guys' that are charging $15,000-30,000.
Also, the Eaton M90 will flow barely more than your engine will on its own at peak. You should only pick up about 40-50hp, and you will be slower than a car with just JHM tune + exhaust.
Since you're in Toronto, there's a JHM tune + catback + downpipes RS4 here...and it's quite badass. I believe it's the red car in the video. Let me know if you want to check it out.
http://www.youtube.com/watch?v=lhDcNObZLpo
#13
#14
The APR kit is fairly decent. I'd say it's probably a bit undersized for the application, but still will garner you decent performance. The RS4 engine can handle more power than the flow of the TVS1320 will allow it to make. Take note - the JHM car in that video that ran 12.4 has recently run 12.30...on 91 octane. He's only running exhaust/tune and a couple of LW mods, and he's only 4 tenths off the time APR posted with a supercharger on 93 octane...and APR stripped out the backseat and trunk floor etc.
Certainly makes you realize that while the TVS1320 is a nice unit, if a tune + exhaust + a few LW parts are only 4 tenths behind it with crappy gas, it exposes the undersized nature of the 1320. APR has admitted they'd have loved to use the TVS1650 but apparently Eaton wouldn't produce them in such small volume for them. Too bad.
Tune should be $500-600 or something...and will work with any exhaust setup in case you stick with the milltek. For what its worth, the JHM downpipes/catback is 2.75" for a reason - they flow bench tested the RS4 setup and found that 2.35" to 2.50" setups can be a restriction to making good power as they're the same/smaller diameter than stock. The car benefits greatly from 2.75" as it allows it to evacuate spent exhaust far more efficiently. For perspective, the 4.2 S4 with a 7000rpm redline and restrictive exhaust manifolds (not the RS4's nice headers) has an optimal exhaust diameter of 2.5"...but you guys with the RS4 have headers and another 1000 rpm of engine speed. It makes sense that you'd benefit from bigger diameter than 2.5 or 2.35, and as the JHM testing/results showed, you do.
This is crazy...one of these is the $1600 Milltek catback, and the other is a stock catback.
![](http://audirevolution.net/addons/albums/images/668062472.jpg)
![](http://audirevolution.net/addons/albums/images/650780120.jpg)
#15
First mistake right there! Ditch the M90. The M112 is better suited, but the TVS blowers are the best for our motors. The PES, and VF are both M90's were the APR is a TVS blower. Go for the APR if your gonna do a kit. They just ran a high 11' at 12X mph! Stock everything except the blower kit.
http://vortechsuperchargers.wordpres...-into-the-11s/
http://www.youtube.com/watch?v=_KIaksAWJb8
#17
I honestly had not been keeping up.
Is there anyone with an RS4 that is extremely happy with their supercharger?
Who makes it? How much? Can you send links?
Thanks!
Thanks!
#18
I don't have a SC on my RS4 but have driven a couple of cars with the APR SC kit.
IMO it is an impressive bit of kit and really transforms the RS4 power wise, whilst retaining OEM like smoothness and noise levels.
If I was looking for more out of my RS4 I'd definitely have the APR SC kit on my list.
#19
Maybe I am in la la Land but now that I've looked at the compressor maps side by side it seems a bottom of the line Whipple or Lysholm twin screw would best suit our 4.2! I am no tuner ace but I have SC'd an e39 540 and looking at the T. Screws compressor maps compared to the current options is a no brainer.. in every way. A 500 cfm pair of Eatons for 12k-15k feels like a bad joke.
The TVS gets its foot into the realm of performance I seek but a Lysholm W100 or W140 at 1120 & 1430 cfm seems ideal with room to grow. I'd think that using a blower with more than enough power then restricting it beats using an inefficient & under powered blower that's going to heat soak simply bc its being pushed to & in many cases beyond its limit. If I am off base here someone please correct me!?
I have to believe there's a like minded Tuner out there who under promises and overpowers.? In the mean time I'm getting the APR system and maybe/hopefully I'll love it. If not I will attempt a blower swap, a few more mods and tune.
I wish I knew of a Tuning Guru here in Seattle. Does anyone?
#20
Seattle area: there is AMD in Woodinville, that has probably worked on the majority of RS4s in the region. Jason the owner is apparently in the final stages of designing a high-powered S/C system for our model. I say 'apparently' since it's nearly impossible to get him to call/email you back .. and he never updates us on forums or his website.
So - let us know what you find out, if you make contact!
http://www.addictmotorsport.com/
