Brand and size and type of SD cards
I read the manual that said you can only
use one piece SD cards
What brand, size and type of SD cards have
you used in your Bose system
I am going to be ripping massive amounts of
music to SD and need to know. I have ipod but
have no ipod and lots of CDs but don't want to
buy the very expensive CD changer
Thank you
John
Thank you
John
Re: Brand and size and type of SD cards
The manual says 256K cards are the maximum. But, I have a 1GB Toshiba SD card that works. MP3 is the only format that will play, however - which stinks if you have a bunch of AAC files from your iPod....
Here's how it works
Even though the max size is 256K, the actual size is much higher. Not sure if that's the limit, but 4G works fine. Also I believe it it's SD cards only (not SDHC).
There's another limit, however. The maximum number of files and directories on each card cannot exceed 512.
So based on the size of my mp3 files I chose to buy a bunch of 2G SD cards, but if you have a lot of hour mixes or 320kbps files you might want to go with 4G.
For more detailed and more accurate information I would recommend you go to navplus.us.<ul><li><a href="http://navplus.us">http://navplus.us</a</li></ul>
As well as Freeware(Win) that manages(Rip->Album/Title info->Playlist) your RNS-E SD files
<center><img src="http://sourceforge.net/dbimage.php?id=126682"></center><p>
<ul><li><a href="http://sourceforge.net/projects/rnse-mp3-mgr/">RNS-E MP3 Manager</a></li></ul>
