Carbon Buildup Porn
#51
Is there a step by step DIY for this cleaning anywhere? I would love to clean her out but would like a little guidance. I'm not mechanically retarded but just not used to pulling engines apart.
Any help would be appreciated.
Thanks!!!!
Thanks!!!!
2007-B RS4
Symptoms: Runs perfectly, never threw a CEL
Hints of power loss: Traction control light quit flickering under full throttle about 1-2 years ago.
Mileage: 33,000
Fuel: Shell 93 exclusively
Oil: 3000 mile oil change intervals, alternating between Castrol Syntec and Pennzoil Platinum Euro
Other: BioSyn Injector cleaner every tankful.
![](http://www.karlabs.com/WGR/RS4/cb/CB1.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB2.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB3.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB4.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB5.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB6.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB7.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB8.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB9.jpg)
![](http://www.karlabs.com/WGR/RS4/cb/CB10.jpg)
Mileage: 33,000
#52
and tell them about your Carbon Buildup Problems. I called today to ask a few questions about the DRC recall and asked the representative how much information she had about the Carbon Buildup issue. She said she hadn't heard of it but she would make a note and that the more people that CALLED IN, the more audi would consider addressing the problem. She said that Calling into AOA was the most effective means of getting the issue heard by Audi. So those of you who have documented cases of carbon buildup should MOST DEFINITELY give them a call and state your case. That is our best hope of getting audi to address this problem.
#53
Audi is aware of the issue, they don't consider it a problem and are investigating it...
they have sent techs around to look at specific cars (the owners wrote a letter)
they have also set up a working group to investigate, including some engineers from Germany
they also monitor the forums
#54
I took my `08 RS4 in for the 25k mile service. It has all the symptoms of the carbon build up problem discussed in this thread.
Dealer is replacing the computer, which is apparently the new audi approved solution to the problem?
Anyone heard of this? Did it work?
#55
I heard they do that because the new ECU is programmed to be less sensitive to the issues and therefore less likely to throw a CEL. Not sure if it's true but that's the rumor.
#56
the latest software contains maintenance/logging/record keeping upgrades
no operational parameters
the count for setting a code based on misfires has not changed
<TABLE class=table-header-alt2 border=0 cellSpacing=0 cellPadding=3 width="100%"><TBODY><TR><TD class=stripe-three vAlign=top noWrap><TABLE border=0 cellSpacing=0 cellPadding=2><TBODY><TR vAlign=top><TD width="50%" noWrap align=left>TSB-01-09-06</TD></TR><TR vAlign=top><TD width="50%" noWrap align=left>Bulletin Date:</TD><TD width="50%" noWrap align=left>May 2009</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=table-main colSpan=2>Vehicle: 2,008 Audi RS 4</TD></TR><TR><TD class=stripe-four colSpan=2>Summary:
AUDI: SOFTWARE VERSION MANAGEMENT (SVM), OPERATING INSTRUCTIONS. SVM IS A PROCESS TO UPDATE THE PROGRAMMING IN FLASHABLE (RE-PROGRAMMABLE) CONTROL MODULES AND/OR TO DOCUMENT CHANGES IN SOFTWARE LEVELS IN AUDI VEHICLES. THIS SYSTEM USES T ( NHTSA ITEM NUMBER - 10032290
<TABLE class=table-header-alt2 border=0 cellSpacing=0 cellPadding=3 width="100%"><TBODY><TR><TD class=stripe-three vAlign=top noWrap><TABLE border=0 cellSpacing=0 cellPadding=2><TBODY><TR vAlign=top><TD width="50%" noWrap align=left></TD></TR><TR vAlign=top><TD width="50%" noWrap align=left></TD><TD width="50%" noWrap align=left></TD></TR></TBODY></TABLE></TD></TR><TR><TD class=table-main colSpan=2></TD></TR><TR><TD class=stripe-four colSpan=2>
#57
I'm told the engine will idle higher on start up to prevent the carbon problem... car comes back today. stay tuned...
that is not true
BADRS4
RS4 (B7 Platform) Discussion
67
02-27-2012 06:27 PM
Epicurus88
Q5/SQ5 MKI (8R) Discussion
59
01-13-2011 12:48 PM
SoCalQuattro
11
09-05-2007 01:05 PM
forced2induce
12
07-21-2006 06:37 PM
