CEL/MIL on -- Low Pressure Fuel regulation 012555 / P310B
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 8E1 910 560 A
Component and/or Version: 4.2L V8/4V FSI ª0060
1 Fault Found:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 2
Mileage: 20309 km
Time Indication: 0
Freeze Frame:
RPM: 2484 /min
Load: 20.8 %
Speed: 49.0 km/h
Temperature: 96.0°C
Temperature: 61.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.827 V
Readiness: 0000 0000
Ross-Tech said "Possible Solutions":
* Check Fuel Pump (G6)
* Check Fuel Pressure
Hmmm... I might just leave that for the dealer.
This came on while driving, so I found it bizarre. Anyone seen this?
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 20309 km
Time Indication: 0
Freeze Frame:
RPM: 2484 /min
Load: 20.8 %
Speed: 49.0 km/h
Temperature: 96.0°C
Temperature: 61.0°C
Voltage: 12.827 V
TSB 24 07 08 June 19, 2007 2015106/1
It's a bad fuel pressure sensor on the low pressure side which may need to be replaced on some FSI engines.
There's no problem driving the car until it's fixed.
Bazman75
12-18-2021 06:10 AM
JiBBeL
15
04-13-2018 08:26 AM
bostonS6
06-12-2008 05:40 PM
