Check switch question
Hello all thanks in advance, I have just purchased an audi rs4 and my battery went dead. I used a charger and I am worried i may have damgaged a relay. When I press the "check" switch a get what looks like error messages.
Also I had a bit of trouble with the rear sunblind. It would not operate untill after i put on the rear heat seating. I know these 2 are controlled by the same fuse so i assume the same relay. I also had a low oil sensor go off a coulle times and the oil level was fine.
My question is do these gauge pics look ok or do I have to worry about electrical damage?
It is possible you damaged something, but when I see warning lights, I assume they are correct. That oil light is for pressure, not level, perhaps the sensor is bad, otherwise it could be an actual failure.
dangelo
A4 (B8 Platform) Discussion
08-26-2023 09:47 AM
Luxus Panzer
07-19-2004 06:18 PM
Audi-Impaired
06-11-2003 08:58 AM
CGTBrad
09-11-2002 08:57 AM
