Coating on MMI screen problem
OK I get an award for SUS, Stupid User Syndrome. I used a Zeiss eyeglass cleaning cloth which had isopropyl alcohol in it on my MMI screen and it looks awful. Took it to my dealer and they said the whole entire system had to be replaced. I have asked Audi to research if I can clean it some way to get the coating off or just replace the screen, not the whole system; they haven't gotten back to me yet. Meanwhile I found www.photodon.com which has the right cleaner for an LCD screen, am waiting for delivery of that. They also have a PROTECTION cover for it...gee wish I had thought of that before. Has anyone else had this experience and what did you do? I'm afraid to keep fiddling with it until I do the right thing...I have a post it on that says "Do not fiddle with this." HELP!
I initially had the car cleaned by a "professional" and they put some interior leather/vinyl dressing on everything, including the NAV screen. It had a nasty film on it that I thought was permanent. Many people say don't use any cleaning chemicals on the screen as it may ruin it, but I figured I'd try glass cleaner before replacing the screen. The screen looks perfect now.
Did it remove the coating or restore it? I think the coating has been damaged and needs to be removed. Thanks.
if that doesn't make it look perfect the anti-reflective (AR) coating is damaged. next option is to clean it again and apply screen protecting film to mask the coating failure. should cover it up nicely.
stoners is available at any autoparts store.
film screen protector is available at any best buy type place. custom sizes should be available online if you can't find a sheet large enough and want to cut to fit.
<center><img src="http://pictureposter.audiworld.com/148925/dscn2782.jpg"></center><p>Sorry it's blurry but to get close enough it turned out that way.
I'm afraid to do anything until I know the right answer. I agree the best thing to do is remove the coating and add a new anti glare protector, but I've tried to clean it more and it just looks worse so I'm trying to leave it alone until I know what will remove the coating.
Thanks for your help
