:: ECS Tuning :: B7 Wheel Spacers & Bolts!!
Audiworld Basic Sponsor
ECS Tuning lets you widen your stance down the road with spacers ranging from a monster 17.5mm offset to a 2mm tweak that makes room for your new brake kit.
Choose from our huge inventory of hub centric spacers in thicknesses sure to match your car, your wheels, and your shopping budget.
All spacers are corrosion protected: 2, 3, and 4mm spacers are zinc plated steel; thicker spacers, in sizes ranging from 5 to 17.5mm, are anodized aluminum. Buy them alone or with matching lug bolts.
Achieve Perfect Stance.
Fits Audi:
A3 (05+)
B5 A4 (96-01)
B5 S4 (00-02)
B6 A4/S4 (02-04)
B7 A4 (05-08)
B7 RS4 (06-08)
B7 S4 (05-09)
C4 A6/S6 (95-97)
C5 A6 (98-04)
C5 S6 (01-03)
C6 A6 (05-11)
C6 S6 (06-11)
D2 A8 (97-02)
D2 S8 (01-03)
D3 A8 (03-10)
R8 (07+)
MKII TT (08+)
V8Q (90-94)
Click HERE to order or for more information
![](http://www.ecstuning.com/marketing/AUDI_B7_A4_S4_RS4_Spacers/AUDI_B7_A4_S4_RS4_Spacers.jpg)
Also be sure to check out our installation PDF HERE
Let me know if you have any questions.
Jason
Fits Audi:
A3 (05+)
B5 A4 (96-01)
B5 S4 (00-02)
B6 A4/S4 (02-04)
B7 A4 (05-08)
B7 RS4 (06-08)
B7 S4 (05-09)
C4 A6/S6 (95-97)
C5 A6 (98-04)
C5 S6 (01-03)
C6 A6 (05-11)
C6 S6 (06-11)
D2 A8 (97-02)
D2 S8 (01-03)
D3 A8 (03-10)
R8 (07+)
MKII TT (08+)
V8Q (90-94)
Jason
Jason, i've been interested in spacers but told by my mechanic that it might throw off something-or-other...i'm not that bright to recall. would a 10mm on front and back really affect the look of my RS4? and does the added width pose any possible negative reprecussions? i know you gotta sell em, but would appreciate your experience.
Fits Audi:
A3 (05+)
B5 A4 (96-01)
B5 S4 (00-02)
B6 A4/S4 (02-04)
B7 A4 (05-08)
B7 RS4 (06-08)
B7 S4 (05-09)
C4 A6/S6 (95-97)
C5 A6 (98-04)
C5 S6 (01-03)
C6 A6 (05-11)
C6 S6 (06-11)
D2 A8 (97-02)
D2 S8 (01-03)
D3 A8 (03-10)
R8 (07+)
MKII TT (08+)
V8Q (90-94)
Jason
Fits Audi:
A3 (05+)
B5 A4 (96-01)
B5 S4 (00-02)
B6 A4/S4 (02-04)
B7 A4 (05-08)
B7 RS4 (06-08)
B7 S4 (05-09)
C4 A6/S6 (95-97)
C5 A6 (98-04)
C5 S6 (01-03)
C6 A6 (05-11)
C6 S6 (06-11)
D2 A8 (97-02)
D2 S8 (01-03)
D3 A8 (03-10)
R8 (07+)
MKII TT (08+)
V8Q (90-94)
Jason
10mm is pretty mild for a spacer so you shouldn't have nay issues.
Tons of customers run spacers with absolutely no negative aspects. Some say you'll rub the inside of your fenders but it all depends on if your vehicle is lowered and the offset of your current wheels.
I hope this helps!
AudiWorld Expert
Yep - I have been running spacers on my car for about four years and they have not been a issue. The only thing you will have to be careful of is getting longer wheel bolts if you do not have more than a few threads of the OEM bolts engaging the rotor.
I ran studs for a few years but then I measured the length of bolts I needed for my summer rims and got rid of the studs.
![Name: f8814a59-6422-400e-a3b9-b9a7015932e9_zps9329a4c2.jpg
Size: 2.54 MB](https://www.audiworld.com/forums/attachments/rs4-b7-platform-discussion-121/84743d1501531836-ecs-tuning-b7-wheel-spacers-bolts-f8814a59-6422-400e-a3b9-b9a7015932e9_zps9329a4c2.jpg)
![Name: _MSP0042.jpg
Size: 3.57 MB](https://www.audiworld.com/forums/attachments/rs4-b7-platform-discussion-121/84744d1501531836-ecs-tuning-b7-wheel-spacers-bolts-_msp0042.jpg)
Thanks for the feed back and posting the pics! Love the white, absolutely stunning! Definitely rare to see an RS4 that color.
Also as a rule of thumb for running the correct size wheel bolts with spacers: Always add the size of the spacer to the stock lug bolt size to get the new wheel bolt size. Ex. 27mm(stock Audi wheel bolt length) + 10mm(spacer size) = 37mm(minimum length wheel bolt that can be used with 10mm spacers).
Cheers!
Jason
Cheers!
Jason
Cheers!
Jason
Cheers!
Jason
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
This is why you really don't want to go too much larger than the width of the spacer added to the stock bolt size when choosing longer bolts.
Jason
AudiWorld Expert
Jason
