EPC (Electronic Power control) light came on today during driving. Anyone know what it means?
I looked in the manual and it's fairly brief as it just says take the car to the dealership.
It was related to the intake motor which is supposed to open up at higher RPMS. There was a vacuum leak in one of the vacuum tubes which was causing this. I think there is a TSB on this.
...your Throttle Position Sensor (TP)/Accelerator Pedal Position Sensor is throwing a fault (via ECM) that the throttle valve (controlled by Throttle Drive) may not be functioning to specification.
If you have/use VAG-COM check the engone control module DTC memory. Otherwise, take it easy & bring to a dealer for diagnosis.
intake manifold failed. The tech found it as soon as the car was put on the computer. My car also fell on its face at 5,500 rpm's. Like the manual says, take it to the dealer.
2 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
P2015 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 33216 km
Time Indication: 0
Freeze Frame:
RPM: 3994 /min
Load: 40.4 %
Speed: 78.0 km/h
Temperature: 90.0°C
Temperature: 15.0°C
Absolute Pres.: 820.0 mbar
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 33296 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 86.0°C
Temperature: 75.0°C
Absolute Pres.: 810.0 mbar
Voltage: 11.811 V
Readiness: 0000 0000
I will call my dealer tomorrow
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 33216 km
Time Indication: 0
Freeze Frame:
RPM: 3994 /min
Load: 40.4 %
Speed: 78.0 km/h
Temperature: 90.0°C
Temperature: 15.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 33296 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 86.0°C
Temperature: 75.0°C
Voltage: 11.811 V
