RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Euro steering wheel....
Old 03-04-2008, 02:51 PM
star607's Avatar
Default Euro steering wheel....
For the last year, I have been clearing a fault code stating control module not coded correctly. Coding is 06021. Is there something I'm missing or does anybody have a similar experience?
Old 03-04-2008, 04:56 PM
Der Kimbo's Avatar
Default Your car is looking for the MF controls for the Entertainment/Communication system
Nothing to worry about.
Old 03-05-2008, 05:29 AM
star607's Avatar
Default Thank you...
but will this fault code show up on every US rs4 with the euro steering wheel, even if it's coded correctly?
Old 03-05-2008, 08:41 AM
S4gasbord's Avatar
Yes. Mine has it too.
Old 03-06-2008, 02:58 AM
PetrolDave's Avatar
No - you should recode the radio/sat nav so it doesn't look for the MFSW any more.
Old 03-06-2008, 06:19 AM
ToblertheDog's Avatar
Default This will continue until you recode...
...the Radio/Navigation System (RNS-E) control module (56). Select an option, relevant to your setup (CD Changer and/or TV Tuner, where the MFSW is "not installed".
You should be set.
Old 03-06-2008, 01:12 PM
star607's Avatar
can you direct me how?
Old 03-06-2008, 08:35 PM
smashtheqube's Avatar
Default I've tried every possible coding and that will never go away... :( Can you guys post a coding that..
...doesn't do this? Post all related devices' codings (Steering wheel, RNS-E, Bluetooth, etc.)
Old 03-07-2008, 03:02 AM
star607's Avatar
Default that was done...
but could you post a all the modules and codes that you have in place. Also could you run fault code check on the steering wheel module prior to this?
Old 03-07-2008, 05:54 AM
S4gasbord's Avatar
Default There will be a code no matter what because the US cars have the extra controls on the dash and
steering column that the Euro cars do not.
Quick Reply: Euro steering wheel....
