RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Exhaust haze under hard acceleration?
Old 06-25-2007, 05:01 PM
Bax
Bax's Avatar
Default Exhaust haze under hard acceleration?
Having been waiting at the front of the queue for a light to change, while idling for a minute or two, I accelerated up to 7,000 rpm in 1st before changing up. I glanced in my rear view mirror and noticed what I can only describe as a trail of haze from the rear of the car. It didn't look like blueish smoke from burnt oil (I'm familiar with what that looks like from some older cars I've owned!).
Could it have been unburnt fuel, or perhaps it was just dust kicked up from the road (it's been fairly dry here lately)?
Car has ~3700 miles on it.
Anyone else noticed this?
TIA
Old 06-25-2007, 05:04 PM
Der Kimbo's Avatar
Normal...Car runs very rich
Old 06-25-2007, 05:11 PM
Bax
Bax's Avatar
Thanks. Couldn't find any other posts on it but was hoping it was normal.
Old 06-25-2007, 06:50 PM
VerrÜckt's Avatar
Default Normal, the amount of "smoke" (Bosch Smoke Number) on FSI cars comes close to that of diesel cars...
at WOT.
Old 06-25-2007, 07:45 PM
RI A6's Avatar
Default hmmm, rs4 runs lambda = .85 at WOT, that's pretty much standard for NA engines
I think you see more stuff because there's a high volume of fuel/air flowing through.
Old 06-26-2007, 06:12 AM
VerrÜckt's Avatar
Default It's not from the A/F ratio, it has more to do with FSI itself.
In order to minimize fuel dillution and oil wash from the cylinder walls, the FSI cars inject early at higher RPM's. The specially shaped combustion bowl on the top of the piston shields the combustion walls from excess fuel wash.
This early injection tends to increase the soot.
Drive behind an RS4 when they punch it. You'll see what I mean.
Old 06-26-2007, 06:17 AM
VerrÜckt's Avatar
Default More reading...
<ul><li><a href="http://bznotes.wordpress.com/2007/01/14/soot-emissions-from-gasoline-direct-injectin-gdi-engines/">Click</a></li></ul>
Old 06-26-2007, 08:19 AM
RI A6's Avatar
Default Re: More reading...
Verr
However, if you read through the Powerpoint slides you'll find that soot for GDI occurs in the stratifed mode, not the homogeneous mode.
PM characteristics of GDI
? Stratified operation improves fuel economy, increases PM
? PM during homogeneous operation is comparable to PFI
gasoline vehicles
? Most current development takes homogeneous approach
Old 06-26-2007, 10:36 AM
VerrÜckt's Avatar
Default homogeneous = lambda 1 = stoich A/F ratio. No soot there. When you go WOT, that changes.
I'm serious, you need to see how much soot an RS4 kicks out under WOT. I think you'll be surprised.
Old 06-26-2007, 11:14 AM
Der Kimbo's Avatar
It's a butt load :-)
Quick Reply: Exhaust haze under hard acceleration?
