Ferodo DS2500 Brake Pad Update
#11
But so can letting brake dust sit on them for a month at a time.
I will generally use a weak stream with soap to wash off the big chunks and provide a carrier for the abrasive material, then spray on some wheel cleaner, followed by a quick power wash. With stock pads it just did not clean everything off. With these pads, I was amazed that the wheels looked bright and sparkley!
#12
watch those wheel cleaners. even those that say safe for painted finishes can stain if left on too long or in direct sun.
i avoid them and just wash with a sponge or soft brush with lots of soap...using the same carnuba wash/wax mix as on the rest of the car. it leaves a protective wax coating on the wheels which makes the brake dust not stick as much and easy to remove next time.
#13
Zeckhausen where out (he shiped the last pair/sets to Korea). Also Raceshopper is out but they are on the way from Italy. 159/set.
Also ordered the Motul race fluid. Totally with freight and 1 1/2 liter Motul about 360-ish.
Thank you RI RS4 for the info!
Jim Meyer
03-02-1999 08:57 AM
