Front stock rotor
one of my front rotors stock rotors have the vanes facing the wrong way. Is it possible to disassemble the two piece rotor and flip the actual disk. All three of the other once are correct.
thanks
thanks
Ok thanks i bring it back to the dealer they did the brakes and rotors 500 miles ago. I just thought it could be done. For some reason the put 2 diver side rotors on the car. Do you think they have replace both rotor and pads? Or the mileage is low enough not to effect anything...
thanks
thanks
Dealer just inform that the front rotors are just one part # NO left or right... But the back are different there is a left and right.. Could this be true doesn't look cosmetically correct in the front??
ETKA shows the same part # for left and right on the front :
8E0 615 301 AB - brake disc (ventilated) 365X34MM 5/112 punched BREMBO
I just looked at my car, and the drill pattern is reversed side-to-side, adding evidence that they're the same part.
DrSmile
08-20-2005 11:04 AM
YS4
04-21-2003 10:58 AM
ZoomS4
01-17-2002 05:09 AM
