Hotchkis Sway Bars in stock!
Former Vendor
![](http://www.purems.com/images/mfg/mfg_10.jpg)
Hotchkis Sway bar kits are back in stock!
Feel the HGUE improvement a set of upgraded sway bars will make on your car.
All H-Sport sway bars feature:
* Tubular construction for lightweight
* Polyurethane bushings
* Bushing brackets with 90 zerk fittings
* Durable powder coating protection
Features:
Lightweight, durable 35MM (1 3/8) tubular steel front sway bar. 60% stiffer than stock.
Lightweight and durable 29MM (1 1/8) tubular steel rear sway bar. Adjustable from +235%, to +305% increase in stiffness over stock RS4.
Greasable polyurethane bushings and brackets w 90 degree zerk fittings.
Gloss black powder coat finish.
Benefits:
Dramatically improves cornering potential due to increased front/rear roll stiffness
Offers definite track and autocross advantage over stock sway bar package
Adjustable rear bar allows suspension to be finely tuned
Car has increased slip angle allowing power to be applied earlier during corner exit
Durable and reliable due to extensive track testing
![](http://www.purems.com/images/fullsize/22832_fs.jpg)
Click Here to Order
A little tech tip if I may...
I have these bars...and love them. There is a sure way to keep the bolts from backing out on the rear bars: add Loctite. For some reason, they seem to back out without Loctite. I told John Hotchkis about this and hopefully, they've updated the user manual.
Despite this, when installed properly, they're trouble free and really make a noticeable difference. A must have mod for our beloved RS4's!
I have both on my B6 S4, with rear set to the stiffer setting. Body roll is gone, mostly neutrel, a bit of understeer is left. I may get the RS4 rear sway....but in reality...I have no need for an over-stearing car. Plus when others drive it, having that setting they could not drive it. I'm getting PSS9's put on FRiday and I hope to dial in a bit more steering by adjusting my dampers.
jjspierx
04-19-2006 01:51 PM
Type44Q
Audi Original "S" Cars
06-14-2003 03:15 AM
