HRE Monoblock Owners
For those running HRE Monoblocks what type(ball or cone) and lengh lug nuts are you running. Just wanted to Know if the stock bolts work. One member had to purchase longer lug nuts and if that is the case that is not right on a high end wheel.
As for ball vs. cone, that's info that should have been given to you by the retailer. If ball seat, *make sure* that they got the radius correct on the wheel. Audi has uses R13 ball seats.
If the HREs are R13 ball seat and you get seven turns, you're good with stock bolts.
60 deg cone
pitch 14 x 1.5
shank dia 14mm
thread to thread 1.5 mm
1/2" ~ 12.7 mm or 8+ threads, you should be fine if you have 1/2" exposed...
iirc you need a minimum of 8 threads engaged<ul><li><a href="http://www.eurosportgarage.com/hr-guide/audi.htm">http://www.eurosportgarage.com/hr-guide/audi.htm</a</li></ul>
pitch 14 x 1.5
shank dia 14mm
