RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
I have a problem: For some reason my wheels are pealing, very wierd. Has anyone else had this proble
Old 06-24-2008, 10:19 AM
  #11
brianja's Avatar
Default I wouldn't recommend using a carnuba on wheels. I like the carnuba look on paint but...
Wheel temps get high and any carnuba applied will likely melt off very quickly. Carnuba melts in your hands when you apply it, imagine how it reacts when on hot wheels.
A sealant like Zaino or Menzerna FMJ, or a wheel specific wax like Swissvax Autobahn will last much longer.
Old 06-24-2008, 10:21 AM
  #12
brianja's Avatar
You also have to be careful not to apply cleaning chemicals to hot wheels.... let them cool fully.
Old 06-24-2008, 10:23 AM
  #13
Senior Member
daveak05's Avatar
Default It's a very small amount in the wash/wax products, there's no melting
or anything like that.
I have used this on my cars for years, basically the carnuba wash/wax and also when washing the wheels.
What it DOES do is keept the wheel surface fairly slick with a slight wax coating, and brake dust tends to not stick nearly as much, if at all.
Try it out once and see what you think...
Old 06-24-2008, 10:29 AM
  #14
Senior Member
daveak05's Avatar
Default All the warings are on the label, but people screw up...
especially people at the dealerships who don't care about the car or are under time constraints. The products are overrated anyway, the lazy man's approach.
Old 06-24-2008, 10:31 AM
  #15
brianja's Avatar
Default I've been using a sealant or a wheel-specific wax designed for those temperatures for years.
Its not that carnuba doesn't work...its just that these last longer than a carnuba will in that application.
Old 06-24-2008, 10:36 AM
  #16
Senior Member
daveak05's Avatar
Default Well, if you want to meticulously apply wax or sealants to the wheels...
but what I'm talking about is just having the carnuba in the wash/wax form. Every time I wash my car(and wheels) it's getting a coat of wax that way.
Every 4th or 5th wash I use a straight wash product to keep the carnuba from building up over time, but that's just me.
I'm sure the wheel sealants are excellent, but it's a lot of extra work and can be a pain on dark wheel surfaces.
Old 06-24-2008, 10:46 AM
  #17
brianja's Avatar
Default Ah. You are using a wash / wax single step. Now I see. I thought you were saying to apply...
a straight carnuba to the wheel instead of the purpose-made products. That made little sense to me.
Personally, I would rather stick to separate wash / wax, so I guess I am stuck using the products I have. Its a preference thing. I would rather apply the waxes to the paint/wheels separate from the wash. I prefer the results and find the process calming.
Old 06-24-2008, 11:01 AM
  #18
Senior Member
daveak05's Avatar
Default Yes, you know, those liquid wash/wax concentrates with carnuba added...
you're right, it's a preference thing.
My cars are garaged, so I very seldom have to hand wax.
I do like the carnuba based wash/wax products because you can see a coat of wax on the car after washing, it's visible. Also, it does not mess up black trim or windows.
It's not the same as an actual hand wax, but it looks good and I know it's offering more paint protection than just a straight wash.
Old 06-24-2008, 03:03 PM
  #19
gap27t's Avatar
Default I have same issue...
I bought the car used about 5 months ago. In the last month, wheels started peeling and at least 2 of them started to get stain spots on them. Took it to my local dealer and they showed me proof that the wheels had been refinished in the past (and not very well). While I think the peeling can be due to a bad refinish job, I can't explain the spotting/staining. Anyway, dealer is having some one come in to see if they can refinish again. I'll post update.
BTW, I tried everything to convince them they should be covered under warranty, but no luck.
UCDaHacker
Q5/SQ5 MKII Discussion
9
10-05-2017 03:28 PM
jsbell_87
11-05-2008 08:07 PM
WhiTTeRainbow
03-08-2005 07:20 AM
Projekt 8E
54
09-07-2004 12:30 PM
dickball
Wheels & Tires Discussion
07-30-2001 08:42 AM
Quick Reply: I have a problem: For some reason my wheels are pealing, very wierd. Has anyone else had this proble
