I want to bypass the exhaust valves. I see the hose that is supposed to be cut off and plugged.
Is there a way to do it without cutting anything. If i fold the hose and zip tie it will it work? TIA
The valve actuator hoses plug into nylon tubes dropping down against the rear bumper.
I unplugged the hoses from the tubes (no clamps on those), and capped the nylon tubes with rubber vacuum caps from Autozone.
Then I wedged the rubber hoses up so they wouldn't flop around.
i have heard that the valves are closed between 850rpm and 4500 rms in 1st, 2nd and 3rd and are always open in 4th, 5th, and 6th. So when i do this the valves are always open. Is the car much louder?
if you disconnect the vacuum lines the valves remain open at all times. it's a bit louder, but after driving a blown z06 with straight pipes for the past three years it still sounds super quiet to me. would like it louder, but haven't decided how i want to accomplish that yet. would prefer a bolt on cat back, but the costs of the available systems seem ridiculous to me.
i disconnected the black rubber hose from the green lines. i then inserted a screw into the black hose and zip tied it so the screw wouldn't fall out. i then zip tied the lines out of the way using whatever was near by to attach to. i get a bit carried away with zip ties
...from when I installed the new exhaust setup.
These should give you some reference on how to handle the ends & where I tied them back...
<img src="http://pictureposter.audiworld.com/70770/img_1265.jpg">
<img src="http://pictureposter.audiworld.com/70770/img_1266.jpg">
<img src="http://pictureposter.audiworld.com/70770/img_1267.jpg">
I am not good at doing things to cars, But I went under and checked mine out and this looks like something maybe I could do. Just one question, Do I plug both the black one that comes from the valve and the nylon one that drops down. Thanks
badinstincts
13
03-12-2012 04:13 AM
Audeye A6
10
04-10-2006 03:43 PM
UseTheS4ce
08-29-2004 11:38 PM
P. Bauer
04-30-2003 03:59 AM
