NO MAG = multiple misfires in multiple cylinders???? or at least that is........
what the dealer found this morning. They cleared them out and the engine light is now off. They are going to look further into it on Wednesday.
But there is a guy up on Cape Cod that had his RS4 at the dealer with the heads pulled and carbon deposits on the intake valves. The factory said it was due to bad gas. This engine may be more sensitive because of direct injection. It will be interesting to hear what your service tech says.
This is one of the reasons why I use FP3000 or FP60 in my fuel. They definitely keep the injectors clean, and help to remove deposits. I keep a bottle in the side pocket of my trunk for every fillup.
FP60 and FP3000 are fuel additives designed to promote more efficient burning, additional cleaning of the fuel injectors and combustion chamber deposits, while adding some lubrication for the fuel pump, injectors and upper cylinder region. FP60 has been around for over 20 years. FP3000 is new and not yet available, except for fleet buyers and some early users.
Here is some more info on them.
http://www.lubecontrol.com/
http://www.lubecontrol.com/faq.htm
http://www.lubecontrol.com/reports.htm
You can order directly from
Odis Beavers
Phone # 214 929 2704/2703
or from the LCD website.
I've also started testing another upper cylinder lubricant, specifically to reduce oil fuel dilution, and should have initial results back in about a month. Unfortunately, it is only licensed for off-road usage.
Odis Beavers
fe342185
06-28-2011 03:51 PM
wuman76
08-21-2005 10:50 AM
Freedom Fighter 001
10-03-2003 08:18 PM
