Optima battery.. Pros and cons anyone?
Haven't really been able to get the whole story on the optima battery, anyone have one of these?
Seems like someone told me it was 35lbs lighter and needs some kit to install, sound about right? Any other details?
AudiWorld Expert
We still have way too much weight up front - not the rear.<ul><li><a href="https://www.audiworld.com/tech/elec167.shtml">A4 Red Top install</a></li></ul>
hence the rear location of the battery to begin with. A 35lb overall weight loss is always nice, but not from this location. I actually added 48lbs to my trunk by adding a subwoofer, box, and amp. Car didn't feel one bit slower, however, it really does feel more poised through corners.
Who'd have ever thought that a sub would be a handling mod!!!
JetJockey knows something about this battery also, so maybe he'll chime in.
the consensus seems to be that you should definitely invest in a battery charger if you get the PC680 (the one that is 35lbs lighter), because the cranking amps are SIGNIFICANTLY less than the OEM battery. Odyssey does make another battery with more cranking amps, but obviously it's heavier (though I think it's still about 11 lbs lighter than OEM).
I don't know if Optima makes anything comparable to the Odyssey.
Truth is stranger than fiction. While I can't dispute the measly number, I swear that the seat of my pants feeling was that the car didn't understeer as much when pushed. Furthermore, since this was not a handling mod, it's also not something I was trying to convince myself of either. It was a feeling that was immediately apparent the first time I took the car for a hard drive right after installing the sub assembly.
BTW...my compliments for accurately coming up with the 0.88% figure. Not a totally intuitive calculation.
USP
TT (Mk2) Discussion
07-19-2007 03:52 PM
TurboEnvy52
12
10-02-2004 05:10 PM
FixedWing
33
09-24-2004 12:29 PM
TwinTurboTerror
10
08-05-2004 02:02 PM
S4Del
08-19-2003 07:41 AM
