PES Supercharger
I am the new owner of a 2007 RS4 that has the PES s/c kit installed. After reading some disturbing posts on the business practices and the reliability of PES and their product. Any insight and experience with this set up would be greatly appreciated. I would like to hear both positive and negative experiences as I am sure there are people on both sides of the fence. Thanks for your help.
AudiWorld Expert
Basically the 'problems' most folks had with the PES kits were around the belt...and the cooling. That was in 2009-2010, so hopefully PES has ironed them out. PES' reputation destruction however was spawned by the cars not making anywhere near the levels of power that were promised.
The supercharger they used, an Eaton M90, is pretty small and will only give you a modest bump over stock power levels. You should probably see a 40-50 hp gain over a stock RS4. THat's nothing to sneeze at...but is nowhere near the 125 hp promises made.
I'd just make sure everything is installed nicely, and enjoy the kit as is. Don't bother with adding meth or anything...it'll be a waste of more money. Consider a 2.75" exhaust and 2.75" downpipes from JHM to increase overall efficiency of the system.
Would be great if you could go to the dragstrip and post a couple of times. See if you can beat Kryptonik's 12.6!
I picked up the car, and the performance is amazing. This thing is a beast! I don't know if I'll take it the strip, but if i do, I will definitely post the times. I'll keep you guys posted.
