RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Small air filter on air intake tube
Old 10-13-2007, 04:01 PM
mkaenel's Avatar
Default Small air filter on air intake tube
So I started to take out my air filter box today and in the process I discovered the small pre filter (looks like a lint screen for a dryer)in the intake tube. It was a mess with all sorts of dust and leaves. After a through clean the car ran much faster. I could not believe it!
Has anyone else found this to help with performance.
It also seemed to run cooler.
Old 10-13-2007, 04:06 PM
BergeyRPI's Avatar
old news for S4 B6 guys. It gets full of twigs and leaves.
Old 10-13-2007, 04:21 PM
Senior Member
daveak05's Avatar
Default it's referred to as the snow screen in Audi lit
some people remove it, and Audi recommends cleaning every 10k, IIRC.
Old 10-13-2007, 07:43 PM
Bob W.'s Avatar
Default you should take a look at the lower half of your airbox some time...
...mine was like an entomology exhibit last time I cleaned it.
Old 10-13-2007, 08:39 PM
Senior Member
daveak05's Avatar
Default 2nd...
when i removed mine to clean, it dumped some debris into the main airbox. had to clean that out of there. this was w/o filter change, but just cleaning the snow screen.
Old 10-14-2007, 06:07 AM
ToblertheDog's Avatar
Default also refered to as the "strainer"...
...part no. 8E0 129 054
Old 10-14-2007, 09:36 AM
Member
Shillens's Avatar
does anyone have pics?
Old 10-14-2007, 11:24 AM
Default No photo off-hand, but part illustration inside...
<center><img src="http://pictureposter.audiworld.com/70770/strainer.jpg"></center><p>...should give you an idea where this micro screen/filter/strainer is positioned.
Accessed by dismantling the intake manifold.
Definitely worth cleaning out every now &amp; then (every oil change, for example).
Old 10-14-2007, 11:55 AM
Member
Shillens's Avatar
Default Re: No photo off-hand, but part illustration inside...
Thanks, but no comprende. Anyone in orange county, ca who knows this stuff who can show me?
Old 10-14-2007, 02:39 PM
Senior Member
daveak05's Avatar
they like to fall out and dump debris into airbox when you remove air horn
Quick Reply: Small air filter on air intake tube
