Sway Bar
No issues w/ cracking the hanger brackets? Just curious as mine are on their way, should have them installed by the end of the week. Did you run w/ the rear set on the softer setting for a while b/4 having set to the stiffer option? wondering there is a substantial difference between the two.
I would not run a different setting on the front v rear. i would run them both on the soft or both on the stiffer setting. I tried the softer setting for a couple of months and then went to the stiffer one and I have not changed back. i love this mod and I think it is a reasonably cheap way to really improve the feel and handling of the RS4 (compared to a full c/o set up).
I have KW Ver 3 coilovers AND Hotchkis sways.
Don't buy the front, you don't need it. And MAKE SURE you use Loctite on the rear bolts or they WILL fall out! I guarantee it!!!!!!!!!
iconoclast
18
02-18-2007 09:05 PM
SereniTTy
11-18-2005 02:37 PM
DenverAvant
06-12-2005 02:35 PM
