Are these the Posi pads someone was recommending?
Need to replace brake pads soon and was going with different recommendations. Are these the posi pads people were talking about?<ul><li><a href="http://www.autoanything.com/brakes/61A4365A0A0A3155407.aspx">posi quiet pads</a></li></ul>
Although they say this is the "value" choice? I dont like "value" anything when it comes to my car... unless its clearly good<ul><li><a href="http://www.autoanything.com/brakes/61A4365A0A0.aspx">Posi semi metallic</a></li></ul>
And make sure you get the stainless lines while you're at it - I got just the Centric Posi Quiet pads and the brakes felt like jello. Upgraded the lines to stainless (requiring the system to be bled) and the bite is much nearer to stock. The only difference I feel now is that the bite is still not there when the pads are cold - when they are warm/hot it's almost identical to stock, with about 85% less dust on the wheels and rocker panels.<ul><li><a href="http://www.zeckhausen.com/Audi/RS4.htm">linky</a></li></ul>
Any issues with a 'boggy' pedal feel with the stock brake lines?
Hows the fade for occasional track use?
Yes, those are the pads. PosiQuiet 104 series Semi Metallics. I just installed them on my RS4 and am quite happy. Nearly no dust, great feel, no discernable difference from the OEM pads in normal driving (i am agressive on brakes).
These are NOT track pads, BTW.
Also, these pads are scorched,a final process that helps speed the bed-in, so I am told. Worked great for me, just a few stabs of the pedal.
Dave Z is a great source for these.
Also, dont read too much into certain web seller's features and benefits descriptions. That AA description is boiler-plate and doesnt reflect the quality and performance of these pads.
Talk to Dave Z...
Talk to Dave Z...
fourwheelslide
03-02-2005 12:32 PM
justinr488
03-09-2004 05:11 AM
Jim Meyer
03-02-1999 08:57 AM
