Trouble with Stasis SL's - Need Advice
#11
With Jason's help have identified the likely cause of my problems. At the time of install I requested that the installer raise the ride height approx 1/2 inch from the initial setting which looked too slammed for me. Jason indicated that when raising the ride height you have to be careful and check the nut on the bottom of the damper assembly to make sure that it has not become loose in the process. If the nut becomes loose, the excess movement will eventually strip away the threads and the damper will separate from the bottom mount. Other than the nut coming loose he could not see why the damper would fail in this fashion. Lesson: make sure to check the bottom nut after any adjustment in ride height.
#12
I assumed a nut but it screws directly into the bottom mounting plate and by turning to adjust the height it can become loose. In the photo the two dampers on the right are the front (the ones that filed on my car) the silver plate under the red spring is where the damper rod screws in. This is where the rod threads that screw into the plate stripped away and separated both times. When you adjust the height at the top of the spring the whole unit can turn and unscrew the rod from the plate at the bottom. I am not a mechanic, but based on my discussion with the Audi mechanic and the discussion with Jason, this is what we believe probably happened.
#14
#16
Look at the dampers with the red circle. At the opposite end of the u shaped bar is a silver metal plate. On the other side of the silver metal plate is where the silver bar of the damper mounts. It is this bar that is separating from the plate and stripping the threads in the process.
CanuckRS4
RS4 (B7 Platform) Discussion
57
01-14-2009 03:29 PM
quattrothatcould
NY / NJ / CT Discussion
11-10-2008 06:52 AM
John Stahmann
24
09-26-2008 10:08 PM
audi90_quattro
01-28-2003 05:56 AM
