Where to have Carbon buildup cleaned in Seattle/Tacoma
#11
I can say that the car does run better when I first start and drive it in the mornings (parks outside). It feels stronger from 3500 rpm up, really I feel like I notice more low end torque. It definitely pulls all the way to redline, but I felt like it did that before. It feels more like 420hp car should feel, it is quicker. But I wouldn't say its like driving a different car.
#12
Great, thanks. My car is with Larson still for a catalytic converter replacement (the second CEL). Once I get it back I'll give Barrier a call to set up a cleaning. Thanks again for the information.
#16
If you have Milltek catless downpipes, you would have a catalyst efficiency code. This can be corrected with o2 spacers, or with an ECU tune, i.e. the JHM one turns off the catalyst efficiency code.
If you have stock downpipes (and cats) then you really shouldn't have a code unless it's something else. If it's 'semi-permanent' does that mean you are able to clear it with vagcom, then it doesn't come back for a while? If so, while you're in there, copy the code and post it in this thread and we can have a look at it for you.
#17
can you expand on this? If you have a Milltek catback, it won't cause a CEL of any sort.
Thanks so much for the information and questions... I appreciate your input!
#18
It turns out the car has Milltek catless downpipes and it's the catalyst efficiency code. The local dealer recommended Achtuning to re-flash the ECU. Does anyone know the implications/consequences of running catless in the state of Washington? BTW - Larson cleared the code with vagcom, and it hasn't reappeared (about 400 miles) yet.
#19
I would wait for the JHM tune to be ready for widespread release and then step into it. They've been the dominant force in tuning 4.2 Audis over the years, and their RS4 program is pretty exciting.
That catalyst efficiency code isn't going to cause you any problems, other than a ghetto CEL which may be a bit embarassing if someone gets a ride in your fancy audi lol.
#20
yeah, let's hold up for a second though. If he's going to tune his car, he ought to get the best tune he can. Throwing a GIAC or APR tune on the car may help the CEL, but let's think about it...a Catalyst efficiency code is a problem for passing emissions testing, and that's about it. It's not a primary control that's going to hurt performance.
