Winter Wheels without Spacers
Hi Guys. Are there any suggestions on 19" wheels (OEM replicas) that I can get for the winter that DO NOT require spacers? I just spoke with someone at VMR and their 708s would require spacers.
<center><img src="http://www.kemsf.com/RS4/images/rs4_snow1.jpg"></center><p>Winter roads are bad, the extra sidewall helps. Hartmann makes a 18x18.5 with perfect offset for the RS4. They are B5 RS4 reps basically. They look decent, offer better ride for winter and require no spacers.
I live in central NJ and realistically the roads rarely if ever get bad enough where I think it will make much of a difference. So I simply prefer the look of the 19s. Is the short answer that 19s without spacers are not available unless I get OEMs?
and the stock 19's just look so great. Why compromise on the appearance of your car for 5-6 months of the year. On the other hand, I do completely agree with you on the issue of extra sidewall protection with the 18's as roads do get beat up during the winter. pros and cons to each.
If the RS4 is going to be a daily winter driver and you live in a harsh winter climate, go 18" with 255/40/18 winter tires. Otherwise, if you have another vehicle for when the weather/roads are really bad, or your winters are milder and your winter tires are "just in case", get a second set of OEM (nothing looks better) and stock size winter tires.
