'04 S4 w/Revo Tune, random misfire (cyls 1 and 3 only)
Can't seem to shake these misfire codes:
16684/P0300 Random/Multiple Cylinder Misfire Detected
16685/P0301 Cyl.1 Misfire Detected
16687/P0303 Cyl.3 Misfire Detected
I took my car in with zero mods (and zero codes). Had JHM piggie pipes and a Magnaflow catback installed, then had the Revo tune done a few days later. Threw all kinds of codes. I have just replaced all the plugs, all the coil packs, and the fuel filter, and the codes are still there. Only things I can think of are:
1. Compression test
2. swap 2 known good injectors with the injectors for clys 1 and 3
anything else I should be looking for? I'm new to Audis so be gentle! ;-) Thanks!
chris
1. Compression test
chris
1. Compression test
chris
1. Compression test
chris
So I went to have the ECU set back to stock last Tuesday and damned if the car didn't start to die on the way there. Tuner was closed, so I limped the car to my mechanic. Felt like it lost a ton of power. He just called and basically there is little to no compression in 2 cyls. They didn't tear the motor down all the way to find out exactly why; he is telling me it would probably be more cost effective to find a used motor. I'm SO mad..only had it about 3 months and I never abused it, but I guess I can't speak for what the previous owner did. So now I have to decide if it really IS cheaper to source a used longblock or have a shop tear it down just to tell me I need a new one.
http://www.audizine.com/forum/showth...th-Big-trouble
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
Alexandroff
11-21-2017 01:45 PM
S4intheOC
09-08-2015 12:12 AM
