17" snow wheel/tire set
xpost<ul><li><a href="https://forums.audiworld.com/b5-class/msgs/4039.phtml">https://forums.audiworld.com/b5-class/msgs/4039.phtml</a</li></ul>
I used to. Narrow tires are much better in the snow then wide tires....
Your speedo will be off ever so slighly but no so much that it will be a problem.
Try the link below plug in the standard size which is 235-40/18 with 205-50/17 The difference is -1.3% which you can get a percent difference just from having fresh versus bald tires.
You do a 215-50/17 you're even closer at .2%. Again this is like a fresh tire versus one thats been drive a few thousand miles.
I would bookmark this page btw it comes in handy.
Side note if you check out snow tire prices on tire rack you'll see that narrow tires cost a lot less.
See what I mean about cars in snow liking narrow tires?
<img src="http://www.cycloneinjapan.com/upload/files/1/subaru_impreza_wrc_rally_car_04.jpg"><ul><li><a href="http://www.miata.net/garage/tirecalc.html">http://www.miata.net/garage/tirecalc.html</a</li></ul>
the purpose of the wintersport is that it's a good tire in the dry + in the snow. i would not run a 205 or 215 in the dry!
to drive in any real snow (like driving to and in Canada) you need a tire that is a little slimmer.
As long as the tires are XL rated you're home free. The LM25's on my car hit 140 a few times no issues (in the dry). Admittingly it does comprimise some of the ride etc. I also like a little more sidewall as pot holes can do a number on wheels. More sidewall offers a bit more cushion from denting a rim when mr pothole sneaks up after a big snow storm.
