18" or 19" wheels in the Northeast
I know this has been talked about before but I'm just about to purchase the B7 rs4 wheels but can't decide if I should get 18" or 19"? I live in the Boston area but mostly highway driving. I want to go with the 19" but people are telling me I'm crazy and I should stick to the 18" Any advice would be greatly appreciated!
little sidewall makes for super stiff compound which puts dramatically increased stress forces onto tread. So, if frequent tire replacement at high $'s concerns you, you may want to pass on the 19's.
i have bent a good amount of wheels. i do not want to go thru that again. it just gets expensive after a few needs replacements. i also do not recommend repairing bent wheels since once a wheel gets bent, that section of the wheel will become weaker since the entire metal composition has changed when heat and pressure is used to repair it....my 2 cents.
i was also thinking of getting coilovers. would the drop and the 245 cause any rubbing? i was told that one solution was to remove one of the large clips in the wheel well.
I have had no rubbing problems with the stock suspension, and have plenty of room. I think I could lower with no problems either.
A5 with 18" wheels or 19" wheels ... are the 19's going to hurt performance as far as acceleration?!
AF 4.2
02-24-2009 04:50 AM
B5QShip
11-30-2004 03:29 AM
