S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
18" vs 19" and performance....
Old 06-21-2005, 12:27 PM
  #11
New Member
Steve Sanders's Avatar
Default Re: 18" vs 19" and performance....
There is a significantly larger selection of 18" track tires at this time.
Old 06-21-2005, 03:13 PM
  #12
kujo's Avatar
that's another great reason to stick with 18's for the track !!
Old 06-21-2005, 05:13 PM
  #13
Junior Member
NIEMALS FOLGEN S4's Avatar
Default I have run my 19" RS6 rims and won't again....
Side wall is to short for the track, as the tire rolls in hard cornering you can mess up the edge of the rim especially when running over gators. Also higher risk of rims bending/breaking completely, bring spare set to the track. Higher cost of 19" rims and tires my falkens are done with one hard event and 3 parade lap drives at highway speeds.
My conti's have 5 events, 10 days, 25 hours on track and 30min on a dry skid pad with center tread still good, side blocks are gone but they still have 3-5 events in them before I get R compounds, even though they are getting louder with each event. And new tires are cheaper in 18" and more choices in R compound than 19"
JD ran his HRE's at VIR and had a horrible time, running far slower than most even with PS2's. A big issue was the reverse lip collecting water and causing vibrations. Wes was running the stock Conti's and going 40-50mph faster than JD.
Old 06-21-2005, 06:11 PM
  #14
BergeyRPI's Avatar
Default Check out the quick Graph I made...
Basically, if you want to accelerate the same as an 18" rim, the 19" rim has to be 1.5 lbs lighter. Torque = Moment of Inertia * acceleration. Therefore, acceleration = Torque / Moment of Inertia. Thus, the smaller the moment of inertia, the larger the acceleration. Don't worry about understanding the units of inertia. Since you are comparing apples to apples, it doesn't matter. All you need to know is the 19" wheel has to be about 1.5 lbs lighter to have the same moment of inertia so that the car will accelerate the same.
Approximations include:
1) Ignoring the spoke weight
2) Assuming each wheel was a 1 inch thick donut that averaged around the 18 or 19 inch diameter
I believe it would be relatively accurate to ignore spoke weight since the only error in ignoring spoke weight is the small amount of weight in the spokes at the last extra 1/2-inch that exists around the circumference of a 19" diameter wheel.
As for assuming the rest of the wheel is a 1 inch thick donut 17.5-18.5 for the 18" rim and 18.5-19.5 for the 19" rim, I looked at pictures on tirerack and decided that should be pretty accurate. To be more accurate, I'd need to create a 3D Ansys model.
Download the file here:<ul><li><a href="http://members.***.net/bergey/18%20vs%2019%20inch%20wheels%20moment%20of%20inert ia.xls">http://members.***.net/bergey/18%20vs%2019%20inch%20wheels%20moment%20of%20inert ia.xls</a</li></ul>
Old 06-21-2005, 11:31 PM
  #15
Senior Member
bla4ck's Avatar
Default let me know when you're ready to buy your Neuspeed wheels...
i'll hook you up with a good deal (no tax too)
Old 06-22-2005, 04:58 AM
  #16
Orangeblood's Avatar
Default How about, keep your stock 18's(with good tires) for track use and get a set of 19's for daily use.
Or pick up a set of cheap wheels that you don't mind flogging the crap out of. There are many options for you. I suggest having more than one set of wheels though. Different jobs take different tools,so to speak.But make sure you get what makes you happy and fits your needs, not other peoples(don't feel pressured to fit in with what is popular).You can spend big money on wheels and it won't improve the value of your car and in alot cases improve the performance either.
Old 06-22-2005, 12:34 PM
  #17
kujo's Avatar
shoot me an email and I can tell you what I have going on....
Old 06-22-2005, 12:36 PM
  #18
kujo's Avatar
Default Stock 18's are long gone.
I'm selling my 19" DTM's and getting some lighter 19's for everday use.
I WILL be getting some light 18's that I don't mind kickin the shiz outta at the track though.
I agree that wheel choice is personal.
this was more a performance question than anything else...
kj
Pauly001
Q5/SQ5 MKI (8R) Discussion
04-19-2013 09:34 AM
b0kix
2.7T V6 Discussion
12-03-2007 03:57 AM
kujo
04-10-2005 04:58 PM
Quick Reply: 18" vs 19" and performance....
