4.2l V8 major oil consumption/leak
Hello, I'm new to the Audi world, and I've recently purchased a 2004 S4 V8. The car consumes/leaks 1 litre of oil ever 100 miles!! I can see no obvious leaks on top of the engine and the timing chain area appears to be dry, also no smoke from the exhaust but a slight whiff of hot oil from engine area. I have yet had a chance to take off the under guards. Is there any common leaks to check for? Thank you for reading and any help you can suggest.
well the 4.2 V8 they threw in the b6's are notorious for losing oil. but 1L per 100 miles is way excessive. my b6 uses about 1L per 1000 Miles. i'm fairly new myself and couldn't tell you were to look first. besides the standard engine places. i would probably check your coolant first and make sure its not a headgasket
Thats super excessive for oil consumption. You or a mechanic should also check the cam tensioner seals, cam seals, and valve cover gaskets (closer to rear of motor) for leaks. Once you are able to take off the skid plates, it will be easier to find wear the leaks coming from.
Good luck!
Good luck!
Check the valve cover gaskets. Also, in my case, a damaged oil cooler was the culprit. From all I've read, the valley pan gasket can be a source of failure resulting in oil pooling under the intake manifold as well.
I’m at round 200-300 when oil light comes on. Did you ever find out what your issue was? Unreal how much oils they burn. Thx.
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
Audi Other 2005 Audi Allroad 4.2L Silver 119k
jbicski
08-30-2015 12:48 PM
A6 4.2 litre
15
04-05-2011 08:17 PM
ColoQuattro
9
01-12-2005 10:53 AM
