S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
After not driving the car for 2 months, rust on rotors have caused
Old 05-08-2007, 06:40 PM
abacab's Avatar
Default After not driving the car for 2 months, rust on rotors have caused
braking problems. I took it into dealer. They say pads and rotors need to be replaced. Not covered under warranty or Audi Advantage. They say this is an 'environmental' problem. Did a search and see that some people have been able to get dealer to replace pads and rotors. Checked out warranty and Audi Advantage and they only cover rotors and pads if you are under 25k miles or 2 years. I'm at 2 years and 40k miles.
Service Manager suggests continuing to use and hope that brake use will eventually clean rust off the rotors. Any other suggestions?
Old 05-08-2007, 06:50 PM
Junior Member
applejacks's Avatar
Rotors and pads are covered for 4yr/50k, unless it changed.. again.
Old 05-08-2007, 06:54 PM
abacab's Avatar
Default I thought they were too. But I just read the warranty and the Audi Advantage
coverage. They are not covered. I called Audi customer service, they also confirmed they are not covered. I called the dealer that i bought the car from, the service manager said they used to do rotors and brakes after 25k but that Audi will not re-imburse them anymore. He said they would cover the pads but that I would have to pay for the rotors.
Old 05-09-2007, 03:45 AM
s4for5_TTfor2's Avatar
Default How bad could it be ? just take the wheels off and use a bit of emory paper or a file to clean em up
It can only be surface rust and there are not many spots on the rotor which will rub.
Pads are very easy to change also.
Post pics please also.
Old 05-09-2007, 04:11 AM
Member
S4 111's Avatar
After tow months...how bad can they be. Normal use should get rid of the rust.
Old 05-09-2007, 06:17 AM
alipor's Avatar
Default Thats odd, is your car an 05? My pads were covered at almost 50k
the rotors were since they were still with in spec.
Old 05-09-2007, 06:49 AM
Junior Member
Car Crazy's Avatar
do a few quick stops from 60 - 10. It will be gone.
Old 05-09-2007, 12:34 PM
Junior Member
applejacks's Avatar
Default More reason why Audi will not retain me as a customer. Also, no worries, it will..
go away on its own. Had the same thing.
Old 05-14-2007, 03:55 PM
abacab's Avatar
Yep...they are much better now.
Old 05-14-2007, 04:00 PM
abacab's Avatar
Yep...did quite a few aggresive stops and it started to get better.
Quick Reply: After not driving the car for 2 months, rust on rotors have caused
