S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Anyone around vegas that has used a fender roller before care to give me a hand plz?...
Old 06-26-2006, 08:32 AM
Member
vegasS4's Avatar
Default Anyone around vegas that has used a fender roller before care to give me a hand plz?...
new tires rubbing alittle need help and my rental needs to go back asap
Old 06-26-2006, 08:35 AM
Former Vendor
Pete @ Stratmosphere's Avatar
Default That is REALLY HARD to do. You can likely...
mis-shape the fender, crack the paint, etc. I've done it before. Never again. Find a pro that can do it. The best way is to remove the fenders, hammer over and re-paint. Which gets you into a matching issue. What I'm saying, is none will be easy. -Pete, Stratmosphere
Old 06-26-2006, 08:42 AM
Member
vegasS4's Avatar
did you do it with a fender rolling tool and a heat gun?
Old 06-26-2006, 08:45 AM
Former Vendor
Default Yes, the one Tire Rack lends out...
and if you heat too much, you will bubble the paint. Not enough, it will crack. And it puts a lot of pressure on the entire fender which can goof up the shape. Did it on two B5 S4s. -Pete
Old 06-26-2006, 08:56 AM
Member
vegasS4's Avatar
well it definatley takes patience to do it right
Old 06-26-2006, 09:00 AM
Former Vendor
Default My opinion is that it's impossible. You will have to hold the outside...
of the fender so it doesn't push out and distort. Insuring that ONLY the lip gets bent. You will also need to modify the liner properly to avoid collecting debris inside the fender as well as keeping it away from the tires. -Pete
Old 06-26-2006, 09:05 AM
Member
vegasS4's Avatar
Default not trying to argue with you but i know of many people whom have done it sucessfully....
so it cant be that impossible to do imo.
Old 06-26-2006, 09:22 AM
Former Vendor
How about this disclaimer. "To my standards" ;-)
Old 06-26-2006, 09:23 AM
Member
vegasS4's Avatar
My standards are = to yours if its done right its done right hence my use of the word "sucessfully"
Old 06-26-2006, 09:50 AM
Former Vendor
Hoping the best for you. If done well, you will be happy.
Quick Reply: Anyone around vegas that has used a fender roller before care to give me a hand plz?...
