Anyone know what this engine fault code means....
or what it implies.....
Address 01: Engine
Controller: 8E0 910 560 A
Component: 4.2L V8/5V G 0020
Coding: 0007711
Shop #:
1 Fault Found:
17983 - Right Engine Mount Solenoid Valve (N145): Short to Plus
P1575 - 001 - Upper Limit Exceeded
Readiness: 0000 0000
Not from my car obviously....(B5 S4 owner)
Oh and the code can be cleared but it comes right back....
Address 01: Engine
Coding: 0007711
Shop #:
1 Fault Found:
A co-worker of mine..... unknown to the forum....
He had a bit of a miss shift incident.... say going from the top of third into 2nd... (instead of 4th..)
LOL!
Yeah, it's a solenoid. That's an electrical error that the vag is reporting. If you check the wiring leading to the engine mount, you may find your issue, otherwise the solenoid is probably bad (wherever that wire leads to).
It's plausible that the misshift caused so much movement that the wires at the mount or the solenoid got tugged enough to dislodge them and cause a short...just a rough guess.
carl viking
40
07-12-2024 02:45 PM
