B6 S4 sparg plug reccomendation
Ready to change my plugs any one have any reccomendations on which ones to use? Do you know if any special tools are needed to do the job? Thanks
Here is a good write-up that I used when changing mine....
Tells you everything you need tool-wise and a good step by step. Plan on about 1.5-2 hours when taking your time. Just get the OEM (Bosch or NGK) as I can't recall anyone raving about anything that they replaced them with over the factory ones.<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/429527.phtml">https://forums.audiworld.com/s4b6/msgs/429527.phtml</a></li></ul>
Very good write up. I used as well. One more bit of advice regarding this......
When you go to pull out the clips on the coil packs, make sure you push the plug in before releasing the clip with the screwdriver. Mine made a clicking noise when unclipped, but I broke off a couple of the clips before I figured out to push the plug further in and then release the clip.
Robson0172
06-06-2008 09:13 AM
DanAudi90
12-09-2004 09:49 AM
