b6 s4 sway bar bolt broke off, anyway to fix it
Hello,
I was replacing my motor mounts with Stern Motor Mounts and had everything all wrapped up when i was tightening the last nut on the sway bar on the passenger side, the nut broke off. This was the last nut. OMG. what to do? Any advice on how to fix this.
TIA,
Jaime
2005 B6 S4, MT, H&R Springs, Milltek Exhaust, RS4 clutch, Stern Motor Mounts, rockford fosgate p3shallow 12"sub, Kenwood DNX9140 DVD player with Ipod, front head light side marker delete, hard wire escort 8500X50
TIA,
Jaime
If you broke the head off of the bolt, you're probably going to have to use some sort of "easy-out" to remove the threaded part that's now inside the hole. You drill a small hole in the middle of that bolt and then reverse thread the easy-out into it. You should be able to find one at Sears or your local hardware store.
BSK
10-03-2007 09:30 PM
Oo.et.oO
05-26-2006 12:48 PM
