CEL when its cold outside < 20degres.
Any ideas? My "04 S4 has been throwing a CEL when its pretty cold outside, <20 degs F. I replaced all 8 spark plugs and coil packs 3 months ago.
Thanks,
Peter
PS: I do have a remote start, which may be causing the 5th code...
Address 01: Engine
Control Module Part Number: 8E0 910 560 H
Component and/or Version: 4.2L V8/5V G 0010
Software Coding: 0007771
Work Shop Code: WSC 02116
5 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - Intermittent
16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 008 - Implausible Signal - Intermittent - MIL ON
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 002 - Lower Limit Exceeded - Intermittent
16559 - Fuel Trim; Bank 2: System Too Rich
P0175 - 008 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Thanks,
Peter
Address 01: Engine
5 Faults Found:
Yes, I chip'd it this year, sorry I failed to mention it. I did have the same CEL codes before the chip. I changed all the spark plugs and coil packs...thinking that its corrected. So I chip'd it when I thougt it was sorted out. A friend has the same year S4 with tip and me and is not chipped and has the same codes...
It is a Revo chip.
It is a Revo chip.
Jehu8
15
10-14-2015 07:10 PM
Audi A6 2003 allroad 2.7t for sale in AZ
blackjulia
09-27-2015 09:37 AM
