Changed from 18" to 17" tires - Here is a report on my initial impressions
I thought going to a 17" from an 18" tire would be a negative experience. The opposite was true. They seemed quieter and more comfortable.
I thought I would go back to the 18"in spring but if my anticipated expectation occurs I will leave these on all year.
They may not look quite as macho as the 18" Conti but I feel more secure.
I will modify this report when I get winter snow experience, I had previously used P210 -- good in snow but very noisy. Very Pleased with the Perilli zero nero M+S 225/45/17.. 400 wear rateing<ul><li><a href="http://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=PZero+Ner o+M%26S">Specs</a></li></ul>
Should be a slightly smoother ride with the extra tire sidewall height.
I have tried 17's on my car, but that was with track rubber and I only drove it that way at the track. 18" wheels should be a little more responsive for track use given less sidewall flex, but that is also what makes the ride a little harsher too.
I will be getting some 17" winter wheels (Ronal R38's) myself in a couple of weeks.
I do use right around 36-37psi on 17" rims. 18's probably need a little more pressure given the
lower profile, but I see no reason to slavishly adhere to that with a higher profile tire.
Our old B5's called for lower pressures (35-37psi) with the 17" wheels. I always found that higher pressures resulted in a rougher ride and wear patterns that showed more wear on the center of the tread than the sidewalls - a clear indication of overinflation.
The old ones left from my B5 - Look the same only 1' shorter. Look here !
<center><img src="http://images4.fotki.com/v42/photos/4/47296/456193/Otto04S4Framed-vi.jpg?1066917248"></center><p>
I was thinking about this too....
I don't have an S4 yet but I'm most likely going to be getting one in a year or so. Anyway one thing I was thinking about was the fact that the stock wheels are very heavy. So what do you do with them? Get a set of lightweight 18" for the summer and use the stocks for winter? Maybe. Or switch to 17". A set of super lightweight 17"'s would make the S4 even faster right?
I did the same thing - winter setup
Went to 17's for winter setup. Only have a few miles on the winter setup, but intial impressions consistent with yours. Ride is a little more muted, but can definitely feel the squishiness of the winter tires (Dunlop Wintersport M3's). Looking forward to the first good snow of the year to assess winter performance.
Captain Rossness
Audi A3 / S3 / RS 3 MKII
26
09-24-2015 05:34 AM
