S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Differences between the 3: E-Codes, Bi-Xenon E-codes & Original 2005 B6 S4 Xenon Headlamps?
Old 03-30-2006, 04:26 AM
Imola Ghost's Avatar
Default Differences between the 3: E-Codes, Bi-Xenon E-codes & Original 2005 B6 S4 Xenon Headlamps?
I've seen some pictures and a few explanations of them but I may be a little confused. Someone told me that if I wanted the Bi-Xenon Ecodes I would need a new ballast, some other things like a longer wiring harness and some other things?
Could someone explain what the differences are? I'm interested in a set of either the Bi-Xenon ecodes or the Xenon ecodes and wanted to know more about them.
I'm pretty sure the Xenon Ecodes are just plug n' play. But I'm more interested in the Bi-Xenon if it's not too much work like cutting the wiring harness and what not.
Thanks
Old 03-30-2006, 05:29 AM
SullyS4's Avatar
Default AWE has a good comparison pic and description on their site
<center><img src="http://www.awe-tuning.com/media/products/awe/comparo_singlevsplus.jpg"></center><p>check them out here...<ul><li><a href="http://www.awe-tuning.com">AWE site</a></li></ul>
Old 03-30-2006, 05:53 AM
I saw that but I wanted to know more about if I needed new ballasts and longer wiring harness'
Old 03-30-2006, 06:28 AM
SullyS4's Avatar
Default No, it should be straight plug'n'play if your car has the stock S4 bi-xenons
I got mine from them recently and I'm installing them this weekend along with LED city lights and silvervision turn signal bulbs. Everything basically swaps over.
Old 03-30-2006, 06:36 AM
Rad-doc RS6's Avatar
any before/after pics?
Old 03-30-2006, 08:02 AM
SullyS4's Avatar
There def will be some b/a pics. I'm doing the install this weekend.
Old 03-30-2006, 09:22 AM
New Member
Rainman4.2's Avatar
Default Yes...make certain you do Bi Xenons if you already have Bi or Single if you already have single...
I made the mistake of trying to upgrade to Bi from single and it will not be plug and play in addition to more money for nothing.
Old 03-30-2006, 10:00 AM
Thanks - I'll look for them.
Old 03-30-2006, 10:59 AM
New Member
Sparta_S4's Avatar
Default I have the single xenon ecodes installed...on my 05 S4
with the signal lights light blue other than the amber. I'll post pics later if I get the chance. With the clear bra on the headlamps to protect from the Crazy Debris around here on 880, CA.
Old 03-30-2006, 11:18 AM
Default oh, and AWE's site says, and I quote....
"If your A4 or S4 came with Single Xenon lights (Xenon only on low beams), choosing the Bi-Xenon (also known as Xenon+) housings is an affordable way to upgrade to the later lens technology," which to me implies its not a waste to get the bi-plus pkg.......
Having said all that, i dont use my brights much at all, so i dont care about it as much. I dont remember a thing about bi or single xenon when i ordered this thing... how do you tell what your stock is?
Quick Reply: Differences between the 3: E-Codes, Bi-Xenon E-codes & Original 2005 B6 S4 Xenon Headlamps?
