S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
DIY Spark Plugs - Spark Plug Replacement Write Up (for noobs like me)
Old 03-04-2008, 11:11 AM
KSpider's Avatar
Default DIY Spark Plugs - Spark Plug Replacement Write Up (for noobs like me)
This is a "Noob" Guide to replacing the spark plugs on a B6 S4 (2004-2005.) I define this as a noob guide, because I will probably say some over obvious things (to some.)
Thanks to those of you in the past who have done some write ups (S4for5 & ESFO, et al), I used some of your photos.
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/thanks.jpg">
I changed my plugs out last night with about 43,800 miles on my car. Audi recommends changing your plugs after 55K miles and they quoted me $460 to change mine. Forum members, including myself will tell you that you might as well change them after 35-40K miles as it will already make a big improvement (and you have to do it anyway.)
On my way home from work I specifically paid attention to the idle smoothness or shake and the throttle response, for a before and after comparison. I let the car cool for about 3 hours; you may need more or less depending on how long you drove the car. Make sure the engine is somewhat cool to the touch before you begin.
Tools I used: Have a few Phillips screwdrivers and a couple flat blade screwdrivers handy (I don't need to picture these I hope)
Vise-Grip Original Straight Jaw Locking Pliers - 7"
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/10r_lg.jpg">
3/8" in Drive T-25 Torx Bit and socket + a Ratchet that will accommodate a 3/8 drive
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/torx.jpg"> <IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/ratchet.jpg">
3/8" In Drive Locking Extension Set (Need about a 6 and an 8 inch extension.) If you already have extensions that don't lock that is OK
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/extension.jpg">
3/8" Drive Torque Wrench (20-100lbs) (need a torque wrench that can do 22lbs)
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/torque.jpg">
3/8" Drive 5/8" Spark Plug Socket (has the rubber inside it)
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/socket.jpg">
Gloves - I used some hardware/automotive Custom Leather Craft gloves from Home Depot... First Step: Removing Induction Runner
Remove the two front screws shown in the picture:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/screws1.jpg">
Then pull the rubber accordion piece off of the front runner piece we just unscrewed, then pull the plastic runner out (towards back of car.)
It should now look like this:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/air.jpg">
Next - Remove the coolant tank screw:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/coolentscrew.jpg">
Next, I unscrewed the two large black screws from the airbox and then pulled it up a little bit, giving another inch or so from the T25 screw on the passenger side:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/airbox.jpg">
Next, Remove this hose from the clip, again, giving more room for the screw below it.
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/hose.jpg">
Next Step! Remove all 4 T25 screws, two on each side.
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/t25.jpg">
These are going to be very tricky. For 3 of them, I had to use the vise grip to hold the T25 bit (Make sure it is VERY tight, you don't want the bit to fall down the engine bay.) It is going to be very slow moving, sometimes only turning 1/8 of a turn or so each time.. Go slowly, take your time.
Here is a pic:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/vice.jpg">
I would do the drivers side front screw first, as this will be the easiest and you can just use a ratchet. This will give you an idea of how big/long the screw is and how it will come out.
When you get to the other three, slowly loosen with the vise grip/T25 bit combo (if you have a ratchet that fits, then perfect!) Test it occasionally when you think the screw should be getting loose to see if you can turn with your fingers. Once you can start turning with your fingers be very careful and remove without dropping into the engine bay.
Ok so you have removed the screws, now on to the coil packs!
First, unclip all four connectors before you unplug them, as they need to be unplugged at the same time (for the most part).
To unclip, grab a screw driver and lightly push down on the clip, pictured here:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/clip.jpg">
I heard clicking noises, some people don't. DO NOT FORCE IT, or it will snap. It may help to slightly push the plug in while you push down on the clip, and then pull the plug out just a little.
Again, do all 4 clips first, and then try to wiggle all the plugs out together (if you do one side, the other side will be at an angle and wont unplug. They are in snug, so just work at it.
Once the coilpacks are out:
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/coilout.jpg">
You pull out each plug, just dig your fingers under them and pull slowly but hard, don't yank it.
I placed each plug in order so I knew where it went back, I don't know if it is necessary I just did it as a precaution.
REMOVING THE SPARK PLUGS
Grab your 5/8" spark plug socket, and put it at the end of your extension/ratchet. Slide the socket into the hole and slowly turn counterclockwise until you feel it drop a little (catch the bolt) and then crank it loose, it should turn 6-10 times. Slowly pull out the socket, and the spark plug should be in the socket (held by the rubber). If it isn't, put it back in and turn it some more. Do this to all 8 and then you are halfway done!
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/noplugs.jpg">
<IMG SRC="http://idisk.mac.com/nkivett/Public/aw/writeups/sparkplugs/old.jpg">
Grab your torque wrench, set it to 22 lbs. and have it ready.
Place a new spark plug in your spark plug socket attached to your extension (not attached to the wrench or ratchet).
Thanks SirTrixMagoo for the following tip!
"Also, you should always make a habit when installing screws and ESPECIALLY spark-plugs, to seat the item before threading to prevent cross-threading. When installing spark plugs, gently lower the plug down into the hole, the rotate the plug COUNTER-clockwise until you feel the plug "seat", it'll square up and you'll feel it (kinda feels like a click), then without lifting the plug, gently turn clockwise to thread. if you feel resistance, STOP, and start over reseating the plug. This is a sure fire way to prevent cross-threading.... something that would be a VERY expensive mistake with plugs!"
Carefully lower the spark plug into the engine and use hand power to rotate it clockwise, keep rotating until you feel resistance (4-5 turns)... Then connect the torque wrench to the extension and finish the job. The torque wrench will click once when you are at 22lbs, stop when it clicks. PULL THE SOCKET OUT SLOWLY. If you do not have the locking sockets, then make sure you pull slowly so the socket does not come off the extension and get stuck in the engine.
Do this all 8 times. I had to finagle a little to get the rear passenger side one in, had to use an elbow connector...
Once all of the spark plugs are in, just firmly place each plug back into its place. Re-attach the coil packs, CAREFULLY screw in the T25 screws (don't drop them).
Screw the coolent tank screw back in.
Replace the hose on the air box.
Replace the two screws on the air box.
Replace the plastic runner intake piece; screw it in with the two screws.
And you are done!
Old 03-04-2008, 11:23 AM
2PUTT's Avatar
great!! looking forward to seeing the completed version.
Old 03-04-2008, 11:25 AM
ESFO's Avatar
There's my pics! I was wondering where they got too, lol... J/k. Nice write-up!
Old 03-04-2008, 12:25 PM
New Member
SirTrixMagoo's Avatar
Default Tip: a 1/4" ratchet and T25 will fit easier into those tight places and limit the torque...
to keep you from over tightening. Once the screws get loose enough, just use the Torx bit hand-held to unscrew it the rest of the way out and start it back in again.
Old 03-04-2008, 12:27 PM
KSpider's Avatar
Good Tips! - Ill add to the write up
Old 03-04-2008, 12:59 PM
SNAFU 4's Avatar
Excellent write up... I will be doing mine this summer most likely...
Old 03-04-2008, 02:26 PM
Corrado79's Avatar
Great write-up. Kudos should also go to S4for5 and ESFO for the original jobs.
Old 03-04-2008, 02:35 PM
AudiWorld Expert
Sia Bani's Avatar
good jerb bud!
Old 03-04-2008, 03:12 PM
mcb001982's Avatar
Great write-up!
Old 03-05-2008, 02:27 AM
Jester7677's Avatar
Good write up. One comment, Husky tools suck. Actually twisted a torx bit of theirs. Go Craftsman
Quick Reply: DIY Spark Plugs - Spark Plug Replacement Write Up (for noobs like me)
