S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
ECU Flash + Warranty = SOL?
Old 05-07-2007, 07:29 AM
RenoAudiNV's Avatar
Default ECU Flash + Warranty = SOL?
Will ECU flash void my warranty? I believe the answer is "depends on dealer", but is there a predominant experience in this matter?
So since i've put my FI fullback system in, i've had CEL. I VAG'd it and cleared an O2 sensor exception. CEL went away for about 2 drive cycles and now it's back.
I would consider ECU flash if for no other reason than to ensure the CEL goes off (flash upgrades account for the impacts of after-market exhausts, correct?). Any negative experiences with chipping?
Old 05-07-2007, 08:01 AM
2PUTT's Avatar
check the O2 sensors. they might have been switched.
Old 05-07-2007, 08:23 AM
bhvrdr's Avatar
Default The problems is your cats. FI should warranty your cats if they are not passing efficiency checks..
they are using a more restrictive 300 or 400cpsi high flow cat to try and pass efficiency but even a quality 100cpsi cat will not set off a CEL. Just show them your codes and ask that it be warrantied.
Old 05-07-2007, 10:09 AM
AudiWorld Expert
Sia Bani's Avatar
Default Edit: Cats don't go that fast. I'd go with Alvin's recommendation below.
Btw, ASP 200 cell cats immediately set off the CEL back in 04 when they made downpipes. Hence why Revo tuning created a CEL shutoff for cat efficiency codes.
Edited thermal to ASP. This was Damon's car...he had a thermal catback paired with ASP dp's.
Old 05-07-2007, 11:00 AM
initialA4's Avatar
whats your code?
Old 05-07-2007, 11:15 AM
RenoAudiNV's Avatar
Default Re: whats your code?
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 8E0 910 560 C
Component and/or Version: 4.2L V8/5V G 0010
Software Coding: 0007771
Work Shop Code: WSC 40232
1 Fault Found:
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 004 - No Signal/Communication - MIL ON
Readiness: 0110 1001
Old 05-07-2007, 11:22 AM
bhvrdr's Avatar
Default Crappy cats will set off a CEL. Ive seen 400cpsi Labree cats set off a CEL...
and i've seen Jet Jockeys 100cpsi race cat never set off a CEL for the tens of thousands of miles he's used it. Similarly i've never had a CEL in 15K miles on my 200cpsi APR cats or my old 200cpsi HJS cats. Some cat manufacturers just arent able to achieve that efficiency though and will instead tell you that you cant have a 200cpsi cat that wont set off the CEL (I had a manufacturer tell me that when I was researching exhausts for my car).
Old 05-07-2007, 11:36 AM
RenoAudiNV's Avatar
Default Here's my Error Code...
1 Fault Found:
Old 05-07-2007, 11:39 AM
AudiWorld Expert
Sia Bani's Avatar
Default That's fine, not arguing that. As a scientist, I'm sure you know that if all else is consistent
one sample datum will not speak for the rest of the population; he just installed the cats...it's much more likely than not, that his O2 censors are fcking up rather than the same cats that many other FI users have on their cars being the cause of the cel.
Now, if they were old cats, I'd definitely agree. Our motor runs hot, and I'd bet most cats that 50k+ hard miles on them will fry, especially given we have several examples of higher mileage stock dp s4s having stock cats go as well.
Old 05-07-2007, 11:45 AM
AudiWorld Expert
Sia Bani's Avatar
Default There you go. Mike, care to confirm here?
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 001 - Upper Limit Exceeded
Readiness: 0000 0000
is a cat code
Quick Reply: ECU Flash + Warranty = SOL?
