S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
ECU Flash + Warranty = SOL?
Old 05-07-2007, 12:09 PM
  #11
RenoAudiNV's Avatar
Default So should i get my 02 Sensor checked on?
Here's the "Readiness" screen:
<img src="http://pictureposter.audiworld.com/117569/enginereadiness.jpg" />
Old 05-07-2007, 12:11 PM
  #12
AudiWorld Expert
Sia Bani's Avatar
Default Based on that, yes. Often times, installers stretch them too much or even the exhaust can fry them
if you're running too lean. (that would be ecu/flash related).
Old 05-07-2007, 12:13 PM
  #13
RenoAudiNV's Avatar
I'll have him check it out, thank you for the tips
Old 05-07-2007, 12:15 PM
  #14
AudiWorld Expert
Sia Bani's Avatar
Default np; btw..i'm running slightly lean too based off the white coloring around my O2 sensors.
but this could have resulted because of my last exhaust being all fubared, etc...gonna checkout my O2 sensors again sometime this summer to see if the new FI exhaust fixed the issue.
Old 05-07-2007, 12:43 PM
  #15
bhvrdr's Avatar
Default Yup, I agree wholeheartedly with Sia. The one he posted is due to cat efficiency while...
Renos appears either a shorted out one or dead. Check connections first.
Old 05-07-2007, 01:12 PM
  #16
bhvrdr's Avatar
Right on. I'm with you.
Old 05-09-2007, 12:35 PM
  #17
RenoAudiNV's Avatar
Default Solution: 1 x new O2 sensor
Here's the deal: Since my new downpipes are shaped differently, the wire harness connecting to my rear O2 sensors was stretched too tight. So tight, that it pulled the wires out of the sensor. The sensors are fine, aside from the fact they are unplugged.
Solution is to buy one new O2 sensor (around 150 bucks) and reroute it from the sensor, down. This allows for a proper wiring route and hence no excess tension. I can salvage the wiring from the sensor i'm ditching to extend sensor #2.
The VAG codes were totally accurate - no signal to sensor indeed.
S4biturbo1
09-10-2011 08:00 PM
Bobby Kinstle
12-11-2007 03:15 PM
2002ar
Audi allroad
10-06-2006 11:43 AM
apb_s4
03-09-2006 05:03 PM
Mr. Head
Florida Discussion
07-25-2004 08:52 PM
Quick Reply: ECU Flash + Warranty = SOL?
