Engine Code help needed .........
I picked my car up from the shop today and was advised that I have two stored codes.
I would like to post up the printout of the code sheet for all to see but I cannot seem to figure out how to do it.
Can someone briefly explain?
Thanks
Thanks
If so, you can post them here or the VAG forum. If you can scan the print out just type in the information
For example:
1 Fault Found:
"01826 - Sensor for Steering Angle (G85)" Supply Voltage Terminal 30
35-00 - -
The information in the quotes is what we'll be looking for.
For example:
1 Fault Found:
35-00 - -
OK here they are:
17979 - Left Engine Mount Solenoid Valve (N144): Short to Plus P1571 - 001 - Upper Limit Exceeded
16825 - EVAP Emission Control System: Incorrect Flow P0441 - 002 - Lower Limit Exceeded - MIL ON
These are both of them. Any ideas?
17979 - check the connector on the motor mount. did you poss hit something? reconnect if no damage. clear fault, perform ecm output check, recheck faults.
16825- clear fault run purge test engine 04 basic setting 070 run test see if system ok.
rcgray001 (11-22-2020)
NotoriousGLU
06-27-2017 06:40 PM
Defon
08-31-2015 11:38 AM
