S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
ESP? ......
Old 05-12-2005, 01:10 PM
New Member
Drewsk's Avatar
Default ESP? ......
I still cant figure out how to turn my ESP off. Also how can my car figure out what others are thinking? What exactly does this do when its off?
Old 05-12-2005, 01:29 PM
Fluffhead's Avatar
Default When you hit the ESP button you will see a symbol light up on your dash......
that means ESP is basically off. What I mean by basically is that even though it appears to be off ESP will still interfere in an emergency.
Old 05-12-2005, 01:33 PM
New Member
Drewsk's Avatar
Default does it give more horse pwr?
or just less grip
Old 05-12-2005, 01:34 PM
Jet Jockey/A4 Pilot's Avatar
Default There are two ways of turning OFF your ESP...
First, the easy way is to push the ESP switch in the dash once. The amber warning light will turn on. This indicates that the ESP or part of it is OFF.
Now I say part of it because the system still monitors you and when you use your <b>brakes</b>, like in an emergency manoeuvre, it will intervene <b>if it thinks you are loosing control</b>. All other systems that are under the ESP's control, Yaw sensor, steering wheel input and traction control (engine cut back) are <b>off line</b>. However the EDL, another traction control system is still on line and will remain active until above 50 mph.
If you want all these systems to be <b>completely off</B>, then pull the ABS fuse. You see, ESP is the brain that manages all these systems but the ABS is the heart of the system, no ABS, no ESP, no EDL, no traction control.
Hope this answers your question
Old 05-12-2005, 01:36 PM
Senior Member
Captain Sheetmetal's Avatar
Default LOL!
...you guys are s-l-o-w!
Old 05-12-2005, 01:45 PM
KMarshall's Avatar
Default Yes, the ESP button will change the rubber compound of your tire's grip
Old 05-12-2005, 01:59 PM
quench_dsm's Avatar
no need to press the button, ESP knows when you want it off...
Old 05-12-2005, 02:05 PM
Senior Member
There we go...glad someone else got it.
Old 05-12-2005, 02:41 PM
Senior Member
Nvr2Fst's Avatar
2nd
Old 05-12-2005, 02:54 PM
ADDICTED's Avatar
Huh !?!?!?!? wait ........... can u ummmmmmm say that again
Quick Reply: ESP? ......
